Results 1 to 6 of 6
Thread: Average prop slip for well setup cats
    Jan 2020
    Az
    515
    Default Average prop slip for well setup cats
    I am curious as to what percentage of prop slip I should shoot for when setting up my boats. I know every setup is different but I know that monos should be around 25 percent for an average setup, is this the same with cats?
    Aug 2018
    Ky
    176
    Quote Originally Posted by BlakeT View Post
    As a guideline....20%
    Jan 2020
    Az
    515
    Perfect, thank you!
    Feb 2019
    NY
    385
    Please explain. What is prop slip ? Is it good or bad?
    AZ
    8,010
    Prop slip is the percent difference between how far the boat would move per revolution using the published pitch value versus how far it actually moves. The more efficient the boat the lower the slip will be - riggers may have less than 15% while a piggy mono might be over 35%. A too-small diameter prop will also have high slip values, sometimes approaching 90%. Slip is a good thing, without it there would be no thrust from the prop. A boat prop is not a wood screw.
    Feb 2019
    NY
    385
    Thanks for the explanation Fluid.
