Results 1 to 3 of 3
Thread: What cause the vibration?
    Apr 2022
    AL
    52
    Default What cause the vibration?
    I finally upgrade the strut and cable to 0.187? but the speed seem slower. I also notice the boat vibrates too much when I rev the engine. What cause the vibration?
    AZ
    8,010
    Are you reving the boat out of the water? If so - stop. Always run with the prop in the water, other than for a quick blip to confirm rotation direction.
    ”Seem slower” - did you measure it? Are you running the same prop and exactly the same strut setting as before? What boat and setup?
    Apr 2022
    AL
    52
    Ah I tested it without water so I felt vibration but after recalibrate the esc, the boat seem normal again.
