Results 1 to 2 of 2
Thread: Twin delta force pathfinder 28", electronics info
    1,453
    Default Twin delta force pathfinder 28", electronics info
    Jumping back into boats after along break i always wanted to build a twin cat the pathfinder looked cool and figured a twin setup might not break the bank. Usually i go with a 36mm motor but the sponsons are narrow so was thinking about trying the leopard x2 2860 motors i think its 3400kv on 2s. With 2x 90 amp escs and props unsure of x440, 442's L&R. Somewhere in the mid 40 mph range
    Some feed back would be appreciated, thanks
    7,629
    I think 28 series would be plenty. I did I Geico V1 quite some time ago and only used stock PB 1800kv’s on 5s. Easily handled the task. I think 442’s were the best prop for my situation. Of course it also depends where you set the stingers.
    Welcome back Steve! I’ve been on hiatus as well(for the most part).
    Shawn
