Results 1 to 7 of 7
Thread: Rigger kanat se?imi ve montaj
    Apr 2019
    Iz
    36
    Default Rigger kanat se?imi ve montaj
    IMG_20220627_192117.jpg ince kanatları taktım teknem d?z gitmedi daha ?nce kalın kanatları kullandım hic sorun yoktu daha hızlı gitmesi i?in daha ince kanat kullanmak istedim fakat d?z gitmiyor acaba a?ılarda bir sorun mu yaşadım
    Apr 2019
    Iz
    36
    ince kanat takıldıktan sonraki sorun video mevcut
    Aug 2008
    7,080
    So, is there a question in here?
    "Look good doin' it"
    See the fleet
    Sep 2011
    Tx
    287
    So it Turkish.
    Here the translation
    i put on thin wings, my boat did not go straight, I used thick wings before, there was no problem, I wanted to use thinner wings to go faster, but the straight?
    Sep 2011
    Tx
    287
    problem after installing thin wing Translation for YouTube video.
    Jun 2021
    MA
    158
    Is your rudder seriously out of allignment?
    Feb 2019
    385
    Pretty sure hes talking about the sponsons when he says wings. Just a guess but I think when he went to thinner sponsons it shifted the CG forward . I don't think the sponsons are big enough, they are partially submerged before he hits the trigger and when he does its submarining the boat. As for turning right is the torque of the prop causing that or rudder not set correctly or are the sponsons not square to the hull of the boat.
