Results 1 to 4 of 4
Thread: Storing motor
    Aug 2009
    422
    Default Storing motor
    Any problem spraying corrosion x in the motor to ensure no rust from any water after I crashed my boat? Motor will not be used until I build a new boat.
    :canada
    4,119
    Definitely would recommend that, and oiling the bearings assuming they're accessible. I would blow out the motor with compressed air first to try to get rid of any existing moisture first.
    Sep 2012
    Tg
    1,439
    You could put the motor in a warm dry place, e.g. on top of hot water cylinder, for a few days to dry any moisture after spraying with corr X. Storing it with some silica gel packets wouldn't hurt either.
    Aug 2009
    422
    Thanks for the information I did leave out in the sun and then I put it in a bag with a couple silica packs I had.
    :canada
