Results 1 to 2 of 2
Thread: New M41 Owner.
    May 2022
    2
    Default New M41 Owner.
    Just picked up a new M41 (green) last weekend. I've read a few threads here and will do a bit more research before upgrading. Sounds like the aluminum cooling jacket is a good piece. I've also seen the dual pickup rudder mentioned a couple times. Never saw any mention of how the cooling system gets re-routed after install though.
    I *was* thinking about using some 3s 3000 75C packs to start but after reading up a bit it sounds like I should get packs about twice that size.
    I will also be looking for a good prop for it to replace the plastic one.
    That's it for now. Have to get the recovery rowboat going before running it for the first time.
    May 2022
    2
    Was going to run Turnigy Graphene Panther 6000 3S packs. Ended up ordering 2 Gens Ace 8400 50C 3s packs. Most everything I've read on here says these boats are on the light side. Hopefully the big packs will help without making it too heavy. The extra run time will be nice too.
