Realize that Gary has had his boat to nearly 110 mph, so there is no comparison with a 50-60 mph oval setup. The aero of the boat was originally optimized for about 45 mph according to Phil, Gary has done wonders with it. Too much angle on the canards may cause them to stall, adding huge drag but little downforce. Weight is a double-edged sword here, adding weight to move the CG forward may help at speed but it can also make the boat difficult to launch. The center of lift changes as the speed increases, but the CG always stays the same.
Every boat has a maximum speed and he may have reached that. He could try small areo add-ons to spoil the lift over top curved surfaces, wider canard surfaces, or small dams to reduce airflow under the hull. Ultimately he will have to consider a different hull. My modified Aeromarine Shadows were rock solid into the upper 90s on 6S for example. That hull does not trap air like the PT boats, but the latter are better overall oval racers.
