Results 1 to 10 of 10
Thread: TP Motor choice
    May 2022
    It
    5
    Default TP Motor choice
    Hello, I have recently purchased a Swordfish X + 220A regulator to be inserted on a TFL Pursuit 6S lipo hull, I have several propellers, the smallest is a 36mm. I was looking at the TP Motor 4050 4Y 1570Kv. Could it be good in terms of current draws? Thanks.
    Sep 2007
    NC
    2,783
    With a 36mm prop the current draw is likely around 150A peak and maybe 120A continuous. As you go up in diameter the current draw will jump quickly to the 200-225A level.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    May 2022
    It
    5
    Thank you very much, I was afraid that the regulator could not stand the amperages.
    Sep 2020
    Tx
    286
    I run the same ESC and same size TP (diff kv) on 4S with a 45mm prop in the same size hull and it pulls 180A continuous without skipping a beat.
    Good combo.
    May 2022
    It
    5
    My fears lie in the fact that I burned two ZTW regulators one 130A and the other 160A with a 2350Kv TP motor with a 36mm 6S lipo propeller. That is why I took a 1570 Kv and would like to be sure of the purchase.
    Sep 2007
    NC
    2,783
    A 2350kv motor is closer to a SAW setup where you need a 300A+ controller or perfect for a 4 cell setup. 1200-1600kv is more typical for a 6S oval setup. You should be OK.
    Tyler Garrard
    AZ
    8,010
    It’s no surprise that the OP burned up his ESCs, a motor KV of 2350 is suitable for 4S, not 6S. On 6S the motor is a SAW setup with potentially very high amp draw. A 1570 KV is a much better choice.
    Sep 2012
    Tg
    1,439
    I run this motor in a DF Pirate 35" on 6s with an RCBB (Flycolor/Raider 150) esc on an M445. The boat will do a heat race and speeds in the 60 mph range. It is probably heading towards the limit of the esc. Previously with a T-180 v2 it ran 97 kph through the lasers, and we have only about 100M run up on our pond.
    May 2022
    It
    5
    This heartens me, I hope not to burn other regulators and enjoy my hull. I'll let you know how it goes when the ESC and motor arrive. Thank you for the advice.
    May 2022
    It
    5
    Hello, I finally managed to put everything together and after a bit of testing I think I have found a decent set-up.
    I attach videos on YOUTUBE to see how it is going.
    Cold engine and regulator temperatures, batteries around 40 ? C.http://www.youtube.com/watch?v=eh3g7YNGva0
