Results 1 to 3 of 3
Thread: 1/12 Proboat Miss Elam Hull
    Mar 2022
    WA
    6
    Default 1/12 Proboat Miss Elam Hull
    I just picked up a 1/12 Miss Elam electric hull. It has the factory rudder and shaft support and tube but no shaft or prop or motor. I'm installing a Leopard 3674 2200KV motor and I need to know what size the factory flex shaft is to order a replacement. Also looking for prop suggestions. Any input would be very helpful.
    Sep 2012
    Tg
    1,439
    Factory shaft is .150. I suggest you find some of the old build threads on this boat. Darin Jordan did a good one. I basically followed that with the one I had years ago. TBH it always ran best with the original 1500kv motor. It has limitations on top speed.
    As far as props go, X442.
    Mar 2022
    WA
    6
    Thank you...What is TBH? I reached out to Steve at OSE for ideas on the engine to use and he suggested a LEO 3674 2200KVwith an OSE Raider 6S 150 amp ESC. I found Darin Jordan's thread on the shaft improvements and will give it a go. Much appreciated!
