Results 1 to 9 of 9
Thread: new props and shafts
    Oct 2021
    fl
    70
    Default new props and shafts
    Would you think something?s not right if you buy new shafts and props and received this? Does something look off?
    OH
    1,585
    what do you think looks off?
    Oct 2021
    fl
    70
    heres a closer pic
    Oct 2021
    fl
    70
    one shaft looks used. they supposed to be 2 new shafts
    4,117
    left and right wind cables often look different, even wen purchased from the same manufacturer. If the discoloring bothers you, you can polish it in a drill chuck with light grit sand paper, but not on the part grabbed by the collet. As long as the cable doesn't appear to be corroded on the surface, or down in the internal winds, I wouldn't worry about it. What I'm more worried about with my own cables is the trueness of the joint between the flex and the stub shaft.
    Mar 2018
    109
    Looks like the right hand might be a 2.25" propshaft and the left hand is a 3"??? If thats what you're talking about?
    Dec 2010
    3,118
    2 brand new aeromarine shafts,, that's what you got,,,, lots of variations of colors in different manufactures and left and right winds like Ryan said
    Oct 2021
    fl
    70
    Thanks for the conversation and explanation, Your a stand up guy, not too many around these days.Thanks
    Dec 2010
    3,118
    Quote Originally Posted by mrd72 View Post
    thank you
