Quick question....I have a 400A esc mounted in a mono with a TP 5680 running 10S. I have tried many props and have found a good combination with the esc, motor, prop, batteries, speed, and run time. The issue that I have is that the speed controller is usually around 110 - 115 degrees when I take it out of the water, but the capacitors are usually 145-165 degrees. Does that matter, do I need more of them, or what do you suggest? Batteries are around 115 degrees, motor is also around 110 - 115 degrees.
Thanks, Eddie
