Originally Posted by
mrd72
took your advice, ran the boat full throttle 90% of time, motors and esc actually ran a little cooler @120F but my batterie?s got up to 140-165F and one got swollen. Ran them to about 3.5V?s after 4 minutes time. the battery that got swollen has IR readings about 1-2 ohms per cell, dont know if it?s damaged though. the other batteries have about anywhere from 1-4 ohms per cell but look fine even though they got hot too. Wow, theres a lot of trail and error trying to get everything balanced to work effectively. Im looking for Dasboata for my new props and go from there
You should not take your batteries below 80% discharge. They got hot and puffed because you over discharged them. If you want longer runtimes you will need to parallel in another set or use bigger capacity batteries.
