Results 1 to 24 of 24
Thread: Leopard motor help
    Aug 2020
    ME
    10
    Default Leopard motor help
    What would be the most powerful/fastest 4092 Leopard motor for a 44" Tunnel hull using a 300 amp ESC--I have been looking at the 930kv and 700kv--Am i looking at the correct KV area? Thank you for your Help.
    Sep 2020
    Tx
    286
    They make the same power. The rpm they spin at is different. You would base the kv on the rpm you plan to spin the prop.
    Aug 2020
    ME
    10
    Hello, With a tunnel hull i would think 25,000 to 30,000?
    Aug 2008
    7,080
    What voltage? 8s-10s? Application? Racing, straightline, or what? Need some context please.
    "Look good doin' it"
    See the fleet
    Aug 2020
    ME
    10
    10S -- Straight line-- Some Racing
    Aug 2021
    325
    Easy to calculate
    3.8V per cell, 12 cells and 700rpm or 930 rpm per V.
    3.8*12*700=~31000rpm
    *930 = ~42000 rpm
    Subtract ~ 10% of the rpm for loss etc, and you are pretty close.
    FR
    2,096
    Single motor setup = 10S or 12S battery.
    10S = 950kV motor.
    12S = 780kV motor.
    Jun 2011
    789
    On 12S with a 44" tunnel and the weight of batteries a 4092 will be marginal for big straightaway speeds. That said stay low on KV's 800 or less and you have the leverage to turn the larger props needed to push the hull. JMO
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    Aug 2020
    ME
    10
    Wanted to go 10S
    Jun 2011
    789
    10S 1000kv or less
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    Sep 2020
    Tx
    286
    Like mentioned, I would run a bigger can than a 4092 for a 44" anything. That's typically 56mm motor territory if you want to be fast.
    Aug 2020
    ME
    10
    I do not think there is a lower unit and adapter that will take a 56mm Electric motor. That is why i am asking about the 2 most powerful 40mm Leopards.
    Jun 2011
    789
    A K&B lower and .187 flex won't take much more than a 4092 motor. You could go with twin outboards and 4082's
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    Aug 2020
    ME
    10
    No Twin Motors
    Mar 2017
    VI
    371
    The 930kv on 8s with an octura x450 should pull somewhere around 75 amps.
    That would give good runtimes. Hopefully an x450 would be enough diameter for that boat.
    The graupner k series props will pull less amps that the octuras. So maybe a k series 55mm is another prop you can try.
    Aug 2020
    ME
    10
    Thanks for the Help.
    Sep 2020
    Tx
    286
    Quote Originally Posted by RC LOVER View Post
    Oh, I forgot about it being a tunnel hull and running an outboard motor.
    ca
    6,963
    Will take some adapter fabricating but...........
    https://www.insaneboats.com/product/...nel-drive-unit
    Mar 2020
    NH
    326
    MHZ has the perfect solution an outboard motor but the motor is inside the hull it looks like a Seven outboard
    FR
    2,096
    You can consider 600 serie outrunner motors
    Aug 2020
    ME
    10
    No Outrunner
    Aug 2020
    ME
    10
    Thanks everyone--Bought a Leopard 4092 700kv from OSE--Had Steve solder on 8mm Bullet ends.
    FR
    2,096
    And what about the battery ? 12S ?
    Aug 2020
    ME
    10
    Yes, Will have 12S
