Results 1 to 11 of 11
Thread: spacer
    Dec 2021
    PA
    17
    Default spacer
    how do i fill the gap when running after market props?
    FR
    2,096
    Use a nylstop screw, not this purple bullet.
    Dec 2021
    PA
    17
    i use the screw then the bullet on the stock prop.the aftermarket has a shorter hub.20220114_091858[365].jpg
    Dec 2021
    PA
    17
    why do the pictures post sidways?
    2,729
    Use a piece of fuel/water cooling tube as a spacer.
    FR
    2,096
    You can reduce the flexshaft lenght.
    Dec 2021
    PA
    17
    then the stock style prop won't work
    ul-19, min-dom, Veles29
    Dec 2021
    PA
    17
    Dec 2021
    PA
    17
    i need the spacer shown above
    Mar 2020
    NH
    326
    you can fill the gap with peek rings(it's a kind of teflon)it gives also no problem with the balance of the propshaft (tfl sells them)
    Dec 2021
    PA
    17
    i found one here at the ose store
