Page 1 of 2 12 LastLast
Results 1 to 30 of 33
Thread: Building the rear wings
    Jun 2021
    Wa
    61
    Default Building the rear wings
    Since I am new to this I need a few tips or direction to a thread on how to assemble the fiberglass rear uprights and wing from Rc boat company. I have all the parts just not sure how to put the
    together and if there is any framework that goes inside.
    thanks!!
    Nov 2017
    wa
    78
    H20.jpg H22.jpg Not my pics but I do it like this also
    Jun 2021
    Wa
    61
    That does look nice, I read some threads where one guy used 1/8" aluminum for the mounts but when I got the plate it seems way to thick so I ordered a piece of carbon fiber hopefully that will be more suitable.
    Not sure why that person is using so much more glass mat to reinforce them. They don't seem flimsy at all.
    Feb 2019
    385
    Make sure to put some foam inside of them to make sure they float in case the worst happens.
    Jun 2021
    Wa
    61
    I have some half inch closed cel foam from a car restoration I did a while back. Any reason why I couldnt cut it into strips and use it in the wings? Will float and not soak up any water.
    Feb 2019
    385
    That should work good.
    Sep 2007
    Co
    3,915
    https://www.ebay.com/itm/35384600591...evt=1&mkcid=28
    this is the best floatation for feathers and wings.
    I realy liked the aluminum rods from RC Boat works ran at a 45degree angle from center to wing.
    https://www.rcboatcompany.com/wings-parts
    Randy
    BBY Racing
    Feb 2019
    385
    Quote Originally Posted by RandyatBBY View Post
    It would be nice if the Rod kit was available. I've been waiting for them for a year now to become available.
    Sep 2007
    Co
    3,915
    Quote Originally Posted by 1coopgt View Post
    After I bought it once I have built my own since then. I do not use the big plate in the middle just ball links to the transom. I use break away tooth picks in the feathers to deck mounts. all the rest of the parts come feom Dubro.
    Randy
    BBY Racing
    Jun 2021
    Wa
    61
    As far as the support kit goes, I have been on the list to buy one for several months. Apparently the guy that makes the bracket on the transom has been ill.
    May 2018
    344
    What retains the toothpicks?
    Sep 2007
    Co
    3,915
    Quote Originally Posted by Mike W View Post
    What I do is when you drill your holes use a 3/32 drill bit. Get round tapered Tooth picks. Take one in each hand and from each side of the feather push the tooth picks intill they stop, you have to push hard to wedge them in. then use wire cutters and clip each side. Then do the other three holes the same. They will stay in the wing untill a crash, they will break away no harm to the Feather or mount.
    Randy
    BBY Racing
    Feb 2019
    385
    I'm planing on using 4-40 nylon/plastic hardware to mount the wings. I pressed 4-40 pem nuts into the carbonfiber mounting tabs on my boat.
    Sep 2007
    Co
    3,915
    That might work , It might also rip the wing or damage the paint
    Randy
    BBY Racing
    Feb 2019
    385
    Not quite sure how it would rip the wings or damage the paint. But stranger things can happen i suppose. I won't be racing the Hydro, no clubs around here. The plastic or Nylon screws are pretty soft and will snap. 4-40 screws aren't very thick. These were recommended by the folks over at Inlwaters.com . Very knowledgeable folks over there when it comes to Hydros.They tend to specialize on Hydros from going through the forums over there. Kind of like Offshoreelectric.com tends more towards Cats and Mono's
    Jun 2021
    Wa
    61
    Lots of good points here! I got an order of nylon hardware and carved up some closed cell foam to fit. Also made a template for the carbon fiber mounts and cut some fiberglass veil to reinforce where the mounting holes will be drilled.
    Might as well dive in!
    6,191
    The last set of tail feathers I did I built them out of wood with layers of carbon. Sort of a hi-bred composite kind of thing. Strong as a brick poop house. Used nylon 440's to attach to the plates at the deck. Crashed......made an absolute mess of course.
    I like Randy's thinking. Set them up so they can come off without wrecking themselves or the boat. Just enough to keep them on while racing.
    Noisy person
    Feb 2019
    385
    Randy do you have pictures so that we can see what your describing. I tend to be very visual . Pics help.
    Sep 2007
    Co
    3,915
    I will get something for you asap. The boat is in the attic and not sure when my son will be over to help take it down.
    Randy
    BBY Racing
    Feb 2019
    385
    Randy
    Don't worry about it bro . You don't have to go out of your way to take the pic's. My Hydro is a multi year project . LOL. So no hurry. If you remember some time great if not that's cool too.
    Jun 2021
    Wa
    61
    I went for it last night and epoxied the halves together with a chunk of closed cel foam in each. Used gflex with a little filler. Once the cure time is done these are goint to need a bit of sanding since they dont fit perfectly together, but it’s probably not going to take much.
    Feb 2019
    385
    Looking good.
    Jun 2021
    Wa
    61
    Ended up needing a bit of filler on the exterior of the seems. I think they turned out well considering I don’t know what the heck I am doing :)
    Jun 2021
    Wa
    61
    Whipped up some carbon fiber mounts for the rear:
    Sep 2007
    Co
    3,915
    I felt steady enough and went up on a step ladder and took some pictures.
    I could not get my son over long enough to get it down.
    Funny I took the pictures with the camera all the same. Some how it flipped loading to the site.
    Randy
    BBY Racing
    Feb 2019
    385
    Looks good thanks for the pics . Stay safe. Don't want you getting hurt on my account.
    Feb 2010
    il
    166
    You can get foam core ready to mount wings from me too.
    https://www.philthomashydros.com/new...le-rear-wings/
    Jun 2021
    Wa
    61
    Those do look nice!!
    Do you have a wing support kit?
    Feb 2019
    385
    Quote Originally Posted by Ayles View Post
    Asking the important questions.
    Thanks for the Link to your site Phil!
    Feb 2010
    il
    166
    See the wing setup page all the parts on there
