Page 3 of 5 FirstFirst 12345 LastLast
Results 61 to 90 of 139
Thread: Slow build - 8S Twin Cat
  1. #61
    7,279
    It’s all about the upright fins, that’s why you are ahead!
    Great looking boat and I love the action shot!
    The fins allow for minute lateral adjustments to be made to improve cornering!
  2. #62
    2,918
    John
    Is that a windshield decal (it looks good)
    I need one, just not sure where to go for one.
  3. #63
    9,402
    Looks good Larry. Did you use teflon in your drive line or just bare brass?
  4. #64
    9,402
    Mono Jeff in here makes nice windshields. If you make a paper template of what you need and mail it to him, he could print you one.
  5. #65
    2,918
    No Teflon Ray, just good marine grease.
  6. #66
    7,279
    John
    Just taped it off and used Testors gloss black paint.
  7. #67
    7,279
  8. #68
    7,279
    The Falcon involved in a cat fight.
    https://www.youtube.com/watch?v=dxeIHTK9sMo
  9. #69
    2,918
    Was that Chris's Cat?
    What was he running in it?
  10. #70
    7,279
    Yup, its was Chris's... If I remember right he had a LMT 3080.
  11. #71
    2,918
    OK - so after debating with myself about the placement of my radio receiver.
    I finally decided to place it at the front away from the motors and ESC's.
    I had built a reinforcement piece for the deck out of 2mm carbon fiber plate that I got from OSE.
    Along with two pieces of the 1/4" carbon square tube that I had. I drilled 3/32" holes in the plate and the tubing.
    I then put it altogether with JB Weld.
    The antenna sticks out 4" high just in front of the hatch.
  12. #72
    7,633
    I like it Larry, a little loom down the middle of hull for Rx power and steering servo would work great
  13. #73
    2,918
    I am working on that.
    I need some black 3" cable ties.
  14. #74
    7,633
    If I would’ve known that I could have sent you out some loom and ties on a truck a week ago.
  15. #75
    2,918
    I picked up some black cable ties, and some 3/4' X 3/4" square tie downs.
    I used all the loom that I had in stock, on the front section between the ESC's and the receiver.
    I then ordered 4 more meters of the black 8MM loom from BC ROTICS in Nanaimo BC.
  16. #76
    9,402
    Can you remember the approximate distance of the motor mounts in your old Mean Machine? It would help give me an idea for my little twin.
  17. #77
    2,918
    Ray here are some pictures, I hope these help.
  18. #78
    9,402
    Thank you, helps a lot. I will mount mine closer to transom.
  19. #79
    9,402
    Did you lay it out for the CG before you committed to that spot or did you just choose a place?
  20. #80
    2,918
    RAY - I did lay it out according to the CG.
  21. #81
    9,402
    Thanks again!
  22. #82
    2,918
    I was working on a couple of Swordfish X+ 200A ESC's today.
    The water inlets were only .095" inside, So I took some measurements
    To see if a piece of 5/32" brass tubing would make it better.
    It will fit.
    So I drilled out the ESC to 5/32" all the way through, then I used a 3/16" reamer to open up the ends to 7/16" deep.
    Every thing would fit like a charm.
    This would make the water flow 2.8 times more then before.
    I then had to come up with a way to make the tubing secure so it would not just slid off.
    Even with a wire tie. I still needed a bump on the end to stop it from sliding.
  23. #83
    2,918
    So I cut a few pieces of 5/32" tubing 1" long, heated one end up and quenched it in water to soften it.
    I took a piece of 3/16" Dia. aluminum . turned the end down to 5/32" to fit into the tubing with a taper at the top.
    I then put this piece into the tube, and used a small tap hammer about 4 to 5 taps, to flare out the end.
    I then heated the end up again and let it Air cool to harder it.
    A little JB weld to hold the tubes in place.
    Now we have good water flow and no change of a water line coming off.
    I think that you could also use a flare kit for 3/16" brake line.
  24. #84
    7,633
    Nice work Larry. Always seems to be room for improvement
  25. #85
    2,918
    Thank You Shawn
  26. #86
    2,918
    Things have kind of come to a halt right now.
    I had to send one of my ESC's back to Offshore for a replacement.
    Water leak from one of the brass tubes.
    Second picture is as they come from Offshore.
    At first I only trimmed the Black heat shrink enough to put the tubing on the brass tube. (see third picture)
    The leak was still under the black heat shrink.
    I did not find it untill I cut off the black heat shrink all the way back to the ESC.
  27. #87
    2,918
    A Little pit of progress, seeing that I am waiting for my ESC to return from Swordfish, And have other boats to clean up and get ready for the race season. I have sent this hull out for a wicked paint job. I will show some pictures as the process continues.
  28. #88
    Jun 2009
    2,539
    Can't wait to see this thing Larry. Nice cooling improvements.
  29. #89
    2,918
    Sneak peak at the paint job for this beast.
    This is only the striping. More to come yet.
  30. #90
    9,402
    Looking FINE! Larry.
