Page 4 of 5 FirstFirst ... 2345 LastLast
Results 91 to 120 of 139
Thread: Slow build - 8S Twin Cat
  1. #91
    Jun 2009
    MI
    2,536
    Very Nice!!!
  2. #92
    ON
    2,912
    This will go on the front deck.
    Larry
  3. #93
    Jul 2016
    4,117
    Simple, and classic. Looks good
  4. #94
    Dec 2011
    On
    560
    A shout out to Lemmy
  5. #95
    ON
    2,912
    Long live Ian Fraser Kilmister.
    RIP
    Larry
  6. #96
    ON
    2,912
    It has been awhile since I posted.
    Too many things going on.
    This is a picture is after first coat of clear.
    Larry
  7. #97
    Mar 2011
    BC
    7,629
    Looks good Larry. I hope you have ‘Good Busy’ going on and all is well. You are going to enjoy this one.
    Shawn
  8. #98
    ON
    2,912
    Thank You Shawn.
    I lost about 6 weeks with Pneumonia, I am feeling better now.
    I am almost finished a new Limited Spec Sport Hydro.
    Then I will start on a new "P" Sport Hydro also.
    Larry
  9. #99
    Jun 2009
    MI
    2,536
    That paint job looks sweet, Larry! I love the Joker theme.
  10. #100
    ON
    2,912
    I turned the pictures, They look even better now.
    Larry
  11. #101
    Jul 2008
    ON
    53
    Looks great Larry!
    Reesor Boat Works
  12. #102
    ON
    2,912
    Thank You Steve.
    Larry
  13. #103
    ON
    2,912
    A couple of new pictures from the painter, 2 coats of clear done.
    Larry
  14. #104
    Jun 2009
    MI
    2,536
    Beautiful. Hopefully I can see it next year at the MI cup!
  15. #105
    ON
    9,401
    Looks awesome Larry!
  16. #106
    ON
    2,912
    Thank You Ray.
  17. #107
    ON
    2,912
    I have decided to go a different direction on the ESC's
    I have ordered 2 - XLX2's, 2- Coolers, 2 - XLX2 Mounting Covers, and the Zinc Oxide Thermal Putty.
    I should have every thing by AUG. first. In the water very soon afterwards.
    Larry
  18. #108
    ON
    2,912
    Two new XLX2's ready to go.
    Larry
  19. #109
    ON
    2,912
    I am getting there. Should have first water test this week.
    Looking for over 70 MPH.
    Larry
  20. #110
    ON
    9,401
    Where and when are you going?
  21. #111
    ON
    2,912
    NOT sure yet. I will let you know.
    Larry
  22. #112
    Aug 2021
    325
    What type water nipples did you use on the ESC? I'm still on stock plastic, but interested in changing.
  23. #113
    ON
    2,912
    I used the 6MM ones from OSE.
    You have to drill the hole out to 5mm, tap it out with a 6mm tap.
    Larry
  24. #114
    ON
    2,912
    First run today.
    Still needs some work on setup. Running wet in the front.
    I had the struts set at 3 degrees down. It was pushing the nose down to much.
    I will adjust them to 2 degrees down.
    The little GPS came back a 73MPH today, Not bad for a first run.
    Larry
  25. #115
    ON
    2,912
    Here is a screen shot from the readout of the Left hand motor.
  26. #116
    ON
    2,912
    Two motors = 24.3HP
    One motor = 8,812 W
    Two motors =17,624 W
    17,624 Divided by 725 = 24.3 HP
  27. #117
    ON
    2,912
    I will try to get one of the other guys to take a video
    for me tomorrow.
    Larry
  28. #118
    ON
    2,912
    https://www.facebook.com/561390943/v...10499214009653
    Here are some Video's from our club run today.
    The video on the top right is my 8S Cat.
    4 laps untill the reverse rotation coupler came lose, lost a shaft and a prop.
    I have got a fix for that problem. 79 MPH on the little GPS.
    Still needs some adjustment's.
    The video on the lower right is my "Q" Cat, 6S.
    I will get some data logs up latter.
    Larry
  29. #119
    ON
    2,912
    I forgot to post this one.
  30. #120
    ON
    2,912
    We had a race last weekend, Gremlins all weekend. Open water on Thursday. Twisted the left hand flex shaft.
    I brought the boat home and did the repair on Thursday evening.
    First race - on Friday I got a DNF (25 points) I had forgot to connect the output water line from the left motor.
    The boat filled with water, It shut down due to a wet receiver.
    I changed out the receiver, but found out the I had also had a dead servo also.
    Disconnected the servo at the rudder and also unplugged it from the radio.
    Second Race - Steering was very poor, had to let off of the throttle to let it turn, then it would DART.
    Canceled out of the rest of the races for this class.
    This is what happens when you rush .
    Even after three years of getting this boat ready,
    I whent to a race with only two test runs on it.
    It will be all set for the next race in two weeks.
    More later
    Larry
