Results 1 to 4 of 4
Thread: Sonic Wake prop recommendations
    Aug 2021
    ON
    24
    Default Sonic Wake prop recommendations
    Hey Guys,
    I am getting a TP 3640-1570 KV as a direct swap for the stock Dynamite and understand i will need to use larger props, more pitch to achieve the speeds of a higher KV, smaller props in the same motor size. I have had some good feedback from other members on picking the right motor without all the mods for a larger can. The stock prop is 1.6x1.73(38x44). For the motor I am swapping, running 6s , and with a sk180a, of this selection made to me: CNC 4414, Octura x445 1.4 ,M445, Grim Racer 42x55 1.3 Prather (but dont have a size), ABC 1614 chopper, which of those listed would be the best to start with? Or am i missing one here ? I am new to R/C boating, and learning as i go, but with props, I have no idea where to start. I appreciate the help here..
    Dec 2010
    NY
    3,119
    start with the 445 and go from there
    Aug 2021
    ON
    24
    Thanks Dasboata for the suggestion.. Ill keep it in mind
    Jan 2022
    HI
    2
    Need prop suggestion for Sonicwake 36 that will be running in saltwater. I am thinking the density of the water will increase the motor heat. Trim ideas would be helpful too. Will be running stock for awhile. Thanks
