Results 1 to 6 of 6
Thread: ESC self programing
    Nov 2021
    TN
    4
    Default ESC self programing
    I have the veles 29 and burt my ESC, I purchased a new one plugged everything in, turned receiver on then ESC and it just keep beeping. My batteries are in storage mode didn't think that would be a problem.
    Anybody know if I am doing something wrong?
    Apr 2020
    702
    Did you remember to calibrate the throttle? If not, that's the cause of problem.
    Nov 2021
    TN
    4
    The instructions said to keep the throttle at neutral, thats what I did. Says the esc will automatically calibrated the throttle range after 3 seconds
    Aug 2021
    325
    What is the make/model of your new ESC? If it's a stock replacement, you are doing it wrong.
    Dynamite 120A
    Ensure proper ESC function by calibrating the ESC to your
    transmitter inputs.
    1.Power OFF the ESC.
    2.Ensure your transmitter is powered ON, the throttle is
    not reversed, the throttle trim is neutral and the throttle
    travel range is at 100%. Disable any special functions
    such as ABS, etc.
    3.Pull and hold the Throttle Trigger to full throttle and
    turn the ESC on.
    4.After 2 seconds a “-B-B” will sound. This means the
    full throttle position has been confirmed.
    5.Release the throttle trigger to the neutral position, a
    steady long “B––” will sound. This means the neutral
    Nov 2021
    TN
    4
    I figured it out! Thanks for responding
    4,119
    The new ESC needs a throttle calibration at a minimum. I would also connect it to a programming card to verify proper timing and other settings.
