Results 1 to 5 of 5
Thread: Struts &rudders for 4s & 6s monos ?
    Jan 2011
    497
    Default Struts &rudders for 4s & 6s monos ?
    Hi all talking to a fellow club member about struts and rudders for 4s & 6s monos on my hulls i use Speed master round bottom mono strut and the speedmaster .21 rudder and extended mono bracket that gives me a distance of 2 3/4 inch from transom to rudders leading edge he mentioned of another boater using a flat bottom Speedmaster .21 hydro strut and an extended rudder bracket with a distance of 4 inches from transom to leading edge of the rudder with the leading edge of the rudder being rounded on the bottom on a 32 inch 4s Finch Wildthing mono . What would be the advantage of using a .21 flat bottom hydro strut and a 4 inch rudder setback ? Regards Andris Golts .
    FR
    2,096
    This TFL 3/16" stinger is great, lenght is adjustable, 75mm to 100mm
    FR
    2,096
    PS : 160mm TFL rudder
    Dec 2011
    561
    I use flat bottom for my P and PL hydros, round bottom for my P and PL mono. leading edge of the rudder needs to be at the drive dog.
    J.
    Jan 2011
    497
    Thanks to all for replying to my post. Regards Andris Golts.
