Page 2 of 2 FirstFirst 12
Results 31 to 37 of 37
Thread: 32 inch F1 Tunnel build: Cozy F1 T800
  1. #31
    Feb 2019
    NY
    290
    Beautiful work.
  2. #32
    Jul 2010
    UT
    59
    Thanks 1coopgt
    The cockpit cowl is cut in shape and fits the hull nicely.
    The maiden run has been done. Without the cockpit for now. The hull runs very well. Top speed with stock 443 prop is 86 km/h or 54 mph. There's more in it with some fine tuning and another prop.
    Here is a snapshot from a near-blowover. The angle of the outboard needs to.be trimmed down slightly.
    Small video:
    https://youtu.be/6gRx32VRygc
  3. #33
    May 2020
    NC
    23
    Amazing work and quite a quick build
  4. #34
    Jul 2010
    UT
    59
    Thanks lilbigmack. Actually I started the build in February 2021 already, so I did not post in the same time frame as the actual build.
    The paint is removed from the hull in the meantime, due to a bad seam between wooden parts of the sponson. Water came in and I had to fix the hull before it got worse.
    I made an outboard cover as well. See below for the actual hull status.
    Outboard cover, made from 6 layers of 80gr/m2 glass cloth over a hard foam mold.
    Painted outboard cover with decals:
    Outboard detail:
  5. #35
    Sep 2021
    MO
    40
    Beautiful work Dirk! the detailed plug and mold work is mindbending! amazing to see what you build as always!
    DYMotorshop 750mm High Deep-V (build)| ProBoat BlackJack 24 (52.2mph) | ProBoat Stealthwake 23 (31.9mph) | Noodle Recovery Barge (6.6mph) | ProBoat JetJam
  6. #36
    Oct 2009
    FR
    1,988
    This guy is crazy! LOL... AWESOME F1
  7. #37
    Feb 2018
    PA
    330
    SUPER nice job so far.....especially the cowling..... !!
