It sounds a bit like a wetbike, wetbikes work, but I guess there are disadvantages as they got overtaken by jetskis and eventually disappeared.
I recall in the early 90s there was a team that traveled the model show scene doing synchronised displays with Robbe wetbikes in the temporary pools doing PR work for the Ripmax (the big RC distributor in the UK), they were unsurprisingly a fair bit slower than what we were racing at the time, but they looked like a LOT of fun.
Technically I don't see what you say as an advantage, if it has a fin at the rear you are not getting rid of the drag of the fin, just making it less effective as it is further away from the CoG and nearer the rudder.
With the angled sponsons I suspect that they would act like turn fins to some extent and I doubt that you would need a fin at the rear, but you would also lose a lot of lift up front and you may need a lifting surface on the front of the tub to act like stumble blocks on a poorly designed cat to stop the front end digging in too far and hooking.
