As you are running a submerged drive, the speed calculator is pretty much irrelevant as it is for surface drive setups. Tbones suggestions on parts are good, however I do not think you will need to run 8s to get you speed goals, 4s will probably be close, but you will have to test it out. I ran the same motor in a 45" mono on 10s with a prather 235 at 63 kph max. This was testing for endurance running and surface drive. It will be finding out the best prop and battery.
