Results 1 to 9 of 9
Thread: RPM unload for a 1 meter cat.
    FR
    2,096
    Default Unload RPM for a 1 meter cat Twin setup.
    Hi,
    What is a good unload RPM for a 1 meter twin setup (39") catamaran? Thanks
    Oct 2017
    LS
    103
    It depends on what you want to do... 30-40k, in SAW-mode it can also be 50+k
    FR
    2,096
    2 x 5S batteries and 3670 - 2280kV motors,
    What do you think ?
    Jun 2009
    GA
    595
    Mar 2020
    NH
    326
    Depending what you want ,but TP4050 1950kv you get setup for all you need
    FR
    2,096
    2 x motors 3670 - 2280kV and 2 x 5S batteries,
    What do you think ?
    Mar 2020
    NH
    326
    personal i should go for a 3682, rpm wise it's a bit high( for saw run ok)1950kv or lower is better then you can use bigger props (for motors SSS or TP price wise good or for the ultimate lehner 1950)
    lower rpm is also depending the load less amp's
    FR
    2,096
    Dec 2011
    560
    Any pics of the build ?
