I have a MG29 which i believe to be a V2. It has the twist lock knob on the back of the canopy between the magnets and a 60amp DYNM3815 ESC. Can someone confirm its a V2?
Assuming its a V2 can someone point me in the right direction for a offset rubber kit or a bracket that allows me to use the factory rudder but offset. I have searched high and low for weeks and cant find a thing. If it turns out that no one makes a kit could someone tell me if the V2 and V3 transom holes to mount the strut/rudder bracket the same "bolt pattern"?
I found this while searching but it appears that its no longer made.
https://forums.offshoreelectrics.com...rudder-bracket
I was thinking if the V2 & V3 had the same "bolt pattern" on the transom i could get the V3 strut bracket and V3 rudder in order to finally get a offset rudder like this.
https://www.horizonhobby.com/dw/imag...&sh=800&sm=fit
Wayne
