Results 1 to 9 of 9
Thread: Vented vs unvented motor?
    Aug 2021
    QL
    29
    Default Vented vs unvented motor?
    Does it matter much between choosing a vented or unvented motor?
    Oct 2017
    LS
    103
    Depends on whether the venting is properly done with a fan or not. Just holes in the housing are only the first half of the story
    Aug 2021
    QL
    29
    It's just I got some tp motors that are a closed, or unvented can, now I'm thinking should I have got vented cans.
    Sent from my SM-G991B using Tapatalk
    Mar 2020
    NH
    326
    if your cooling works good then open or closed is no problem ,i have a closed 4070 and TP says with cooling no problem .A lehner motor has a cooling fan in the motor that helps to cool the inside of the motor very good
    Oct 2017
    LS
    103
    TP are not optimized for ventilation so don't overestimate the housing to have holes or not.
    Ventilated Lehner and Neu have fans so there it is a different story.
    Sep 2007
    2,783
    I prefer vented motors to allow any moisture to escape. Although minimal, the rotor does create airflow within the motor and this does help cool the rotor. It's also allows some natural convective cooling to take place after a run.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    Mar 2020
    NH
    326
    an other thing to go for a vented motor ,i use a cpu fan on the back of the motor to create a perfect storm in the motor.i use a tp 4070 1400kv 7s in a mono with a fan on the back and with water and air cooling the highest temp i've seen is 22C on the motor (prop abc 2015-19)
    2,733
    Unless you're filling your hull with sand at athe beach vented is the way to go for all the reasons already mentioned. However personally I wouldn't take the financial hit selling second hand sealed cans to get new vented ones.
    9,402
    Quote Originally Posted by MidKnight View Post
    If you have a drill press and the skill, you could vent them your self. I have done this on some motors. You need to remove the front and rear covers to do it or you will destroy the windings.
