Results 1 to 5 of 5
Thread: mamba xlx2
    Aug 2009
    422
    Default mamba xlx2
    When using a separate rx pack do you remove the red wire from the aux wire too or just on the receiver wire?
    :canada
    Sep 2007
    2,783
    Remove the middle wire from both. The second set of wires also run power for higher BEC loads so it needs to be removed too.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    Aug 2009
    422
    ok thanks Tyler
    :canada
    May 2014
    636
    One other thing. I hate to muck around with the ESC connector itself, so I make the mod to a short extension lead.
    Ron - The Villages, FL
    Aug 2009
    422
    That’s what I did used a short extension lead with the red wire removed.
    :canada
