Hann,
The Cheetah twin or single question has come up here in the past. I'll throw in my 2 cents - I've built a few for customers - 4S single motor ones for casual fun racing mostly like you're talking about. I do however know of two experienced racers who use twins for oval competition (P-Class - 4S ) and they are pretty slick. I personally avoid twins - they are a bit tricky to build - lining up the motors/mounts/drive components with precision in the tunnels isn't my idea of an easy task. My personal Cheetah uses one TP 4060 2040 KV motor on 4S and it flies. I haven't oval raced it but did almost kill a NAMBA 2-lap record with it (my driving stinks and I had a servo quit in the last turn of a record beating run so I gave up that day ). I'm biased towards a single motor for several reasons - twins are tricky to build, cost a bunch more than a single, and more to get out of whack. And consider this : If you're going roundy-round with other boats and your CF hull flips on the back straight it'll be mostly invisible as the cf visually blends into the water and your nifty rig will become an invisible speed bump for your playmates even in the unlikely event each of you has a pitman/spotter at your shoulder. Bright colors are best.
Single on 4S2P :
https://www.youtube.com/watch?v=Cl5ebHR6wR4
