Results 1 to 5 of 5
Thread: 1st Scratch Build, $70 Rescue Boat.
    Nov 2012
    178
    Default 1st Scratch Build, $70 Rescue Boat.
    Made extra wide just in case the 15" wide ProBoat 42, is in the future.
    Electrics purchased as a Combo. Bench tested on 3s, at full song it made a shrill sound similar to something heard in a Horror Movie.
    Esc says up to 4s. On 4s, a 40amp ESC and a 2300 kv motor... How long before...
    Gunna go with 2s and traveling a blistering 4mph in route to the crime scene. (Fishing pole will still make the trip.)
    The Good: Learned how to install an airplane prop. There's actually two ways of doing it...
    No more swimming.
    The Bad: Airplanes don't have a reverse.
    Build Reference Video Link:
    https://www.youtube.com/watch?v=ajW0ciXoGYU
    How to make an RC Rescue boat - YouTube
    Note: Some PVC cm measurements in video are not correct.
    AquaCraft UL-1 59mph.
    Motley Crew 61mph.
    JAE 21FE ~~~ 70 MPH Club ~~~
    May 2014
    636
    Good work. You will need something hanging down to capture the stranded boat.
    Ron - The Villages, FL
    Nov 2012
    178
    Thanks. Does have lawn trimmer line (green) running across the bottom of the back. In testing, I'm guessing the kv is to high & the prop is to small.
    Looking at an 1100kv motor that comes with a 10" prop, current prop is 6". What do you think... looking for some advise.
    Motley Crew 61mph.
    May 2014
    636
    High KV & small prop is for racing planes, not barges.
    1100 KV and 11x6 prop should be OK on 2S. I use 3S with a 950 KV motor and 10x7 prop. Also use a SeaKing 60 amp boat ESC with reverse. Current draw is low enough to get by without water cooling. Club has about 10 of these rigs, 2,3,4 & 6 cells.
    Nov 2012
    178
    Default The Barge
    Quote Originally Posted by zooma View Post
    From a Proud First Time Owner of a... Barge,
    Thanks!
    Motley Crew 61mph.
