Results 1 to 3 of 3
Thread: MAeromarine 48 popeyes build
    Jul 2021
    4
    Default MAeromarine 48 popeyes build
    Has anyone ever put a twin brushless system in this hull? If so what did you use and what was the mph?
    Sent from my SM-G998W using Tapatalk
    Cool
    I suspect not, since the hull isn?t particularly suited to them. If placed in the sponsons the props will be out of the water - this is not a traditional catamaran design. I suppose that you could put twins in the center section - some have built twin monos in that manner - but the hull is really best suited for a big single on 8S to 12S.
    A large hull like this is not likely to reach the high speeds of similar-sized cats, what is you speed goal?
    Jul 2021
    4
    Thats what i figured. I have a single 12s aquastar system. Goal is around 90-100mph... idk if its going to be possible but we'll see
