Results 1 to 6 of 6
Thread: CF boat
    Jun 2020
    MA
    90
    Default CF boat
    I have a newly acquired boat that is carbon fiber. Will the reception be ok in it? The hatch is also CF. I have a futaba 3pv with the r304sb rx that i will be useing.
    Aug 2015
    199
    Antenna from receiver must be outside of the boat regardless of tx and receiver you use.
    If you use a gps to measure speed, it also needs to be mounted on the outside of the hull.
    CF blocks all reception that I know of.
    Jun 2020
    MA
    90
    So if my antenna is sticking out the back im all set?
    Mar 2020
    NH
    326
    keep in mind the antenna should not be shielded by the spray on the back of boat
    4,117
    Quote Originally Posted by Jonathan DeMaria View Post
    Yep
    Jun 2017
    RH
    51
    Yes, and te antenna should not touch the Carbon. despite of this precaution, you will have less range than with a fiberglass only boat. I see that with a Spektrum Radio.
