My racing history is Nitro/gas so forgive me as electric is still a work in progress.
My son it getting his first season of racing in with a Veles 29 cat in NAMBA P.LTD. Hydro racing. Yes hydro... This class runs on Sunday(I am not available Saturdays) and several cats are driven by junior boaters along with a couple of seasoned vets racing riggers. Sort of like a Prototype/GT mixed format race.
The Veles has the stock Dynamite DYNM3831 2000Kv 6 pole motor/ Dynamite ESC (no visible spec but it is the same blue as the motor) an upgraded dual water pick up rudder, upgraded flex drive and the sharpened and balanced prop available on the OSC website:
Prop Specs: Similar to ABC 1716-17-45 prop.
Diameter: 43.1mm (1.70") diameter
Pitch: 1.6 pitch
(same specs as the stock prop)
The boat is as fast/faster as any of the other cats, most of which run Leopards. The issue is battery duration.
It is running on 2 2S 5000 mah lipos and it will barely make the 6 laps for a race finish or hit the ESC min limit at 5 3/4 laps and stop before limping across the finish. The batteries were coming out quite warm and between 15-11%. Ouch...
2 different sets of batteries were used for the races. Turnigy nano-tech 5.0 35-70c and RevLectrix Blend420 Go Pack Silver Label 70C with similar results but the Turnigy lasted 3-4% longer in both of their races.
Love the prop but it is drawing a lot of amps. The motor and ESC are never overly warm, XT90s with good wire and solder, with the dual cooling lines it seems to be handling the loads so far.
I raised up the prop about 1/16 for the last race but it seemed to have zero effect on boat speed or battery lift. Likely I didn't move it enough to have an impact.
What is the right move to not only finish 6 laps but have enough for a 7th if a buoy cut is involved?
Specs for P.LTD are:
11.10 ‐ 16.92 V
10,000 mah max.
Bigger lipos are not an option as I am already at 10k.
Never considered/don't know enough to go to a different voltage but I guess going up to 3S is an option? Good or bad option?
What is the best trade off to get more run time?
What would be a slightly smaller prop that the OSE prop?? What about a 3 blade prop? 645/3 was mentioned somewhere on this forum.
Pitch: 1.6 pitch
