Results 1 to 11 of 11
Thread: 2bld to 3bld Q
    Apr 2010
    643
    Default 2bld to 3bld Q
    I am running a 4814 two bold If I go to a 4518 3 bld is that smaller? I am running a 2030 KV UL1 motor. I want the same speed as the two blade but I want the stability of the three blade
    Oct 2017
    LS
    103
    You change about everything, number of blades, Diameter and Pitch.
    The result will be a surprise and very much depending on the boat.
    The 6,7% of change in diameter will not compensate the 28,5% Pitch-Change.
    If both pitch-ratings are true (which often is not the case ) the 4518 will try to make the boat go much faster but this is simple rule of proportion. Whether the boat can handle the speed is a different story.
    9,401
    Hey Gary, sent you an Email regarding paypal...
    Get back to me.
    Apr 2010
    643
    Ray I sent you the money via PayPal . I know you sent me an email but I didn?t get it. My email is garyaaandmargy@yahoo.com
    Jun 2011
    789
    Just a question. What boat and batts are you running with an AQ2030? "Q" in the title 6S? Fun run, SAW, 6 laps heat racer? All would help us assist you in prop selection.
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    Apr 2010
    643
    I have 2 tenth scales Vint. and Modern. Extremely fast. Vint. has a 447/2 & Mod. a 4814/2. We run a short course and I need more stability. Both CF . They deserve a better driver. thank you for any advice
    6,191
    Quote Originally Posted by HTVboats View Post
    Mic
    Think Q means question
    Noisy person
    Jun 2011
    789
    Ok shorthand acronyms, I didn't get the translation manual. In that diameter and pitch range I would look into a DR. Props 645/3
    http://doctorprops.torgg.com/collection/3-blades
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    Apr 2010
    643
    I am running 4s P LIMITED 50C 6000 mAh
    9,401
    What brand?
    Apr 2010
    643
    Rcbattery.com
    i also got your refund thank you
