Results 1 to 4 of 4
Thread: motor wires de soldering themselves
    Jun 2021
    IA
    Default motor wires de soldering themselves
    motor wires keep de soldering themselves from the esc. sometimes one but usually two. ive got seaking 180 esc with i think a 4074 leapord 2200kv. running on 6s .. any ideas why??
    2,731
    you are overpropped.
    Jun 2011
    789
    2200kv on 6S. That's 48840 rpm no load. As stated this is probably a function of over proping and the result is heat. Your solder joints are sending a message. If they held longer the motor wires would be the next to fry. Running with rpm's in that range a small prop change can push things over the edge very quickly.
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    Cool
    If the OP gave us some additional information we might be able to give him more specific help.
    Exactly what boat?
    Exactly what prop?
    Exactly what battery?
    How long does he run before the solder melts?
    What is the size of his pond?
    How much part throttle running does he do?
