Page 2 of 2 FirstFirst 12
Results 31 to 35 of 35
Thread: Ml Boat works 1/6 dual build thread, Newton 164 and 172.
  1. #31
    992
    J man.. I think your motor is way too far back! Can you get it a little farther forward?
    Lol
  2. #32
    992
  3. #33
    Jun 2021
    Wa
    61
    What material are you using to create the nose piece?
    I also see you used blocks of foam? I am rescuing a half built boat where those pieces are shaped out of wood and appear to quite chunky. I might cut them out if the wood blocks are a bad approach. What will you cover the foam with?
  4. #34
    992
    Quote Originally Posted by Ayles View Post
    The nose block is shaped/sanded basswood core. I used poly foam blocks to form the cone. The light blue stuff is Icing which is similar to bondo but easier to sand.
    The white foam blocks that you see are used to guide the 1/16” ply that will go above and below. I coated the foam with g-flex. If I weren’t covering the foam with ply then I’d use icing or bondo.
  5. #35
    992
