Well I didn’t document the build; it was done before I knew it.
I ended up cutting the hatch too short and had to make my own.
Black epoxy was used to seal the wood and the cowl was sanded.
"Look good doin' it"
See the fleet
Then I sprayed the cowl and the pieces of carbon fiber/Kevlar with 3m contact cement and affixed the cloth. Then I applied two pumps worth of west systems epoxy. Once cured and sanded lightly, I added a layer of black epoxy.
Once this is good and cured, I’ll finish with bondo and another layer of thick 5min epoxy.
See the fleet
The hull sealing method is my latest technique: dyed black epoxy cut with 1/3 acetone to thin, and spread with a 2mm thick piece of acrylic spreading tool - using the factory edge, so it’s super smooth! Just enough to seal, but no more. Way less sanding too!
See the fleet
Finished product.
After two bondo/sanding sessions, I painted another layer of black epoxy.
One last sanding and it will be ready for paint!
See the fleet
Nice work Jesse.
Nice! Isn’t that a fun kit to build. It falls together...unless you cut the canopy short
Yep great kit.. was built before I could grab the camera!
Here is trials paint scheme.. plan to paint mo betta soon. These are vinyl graphics I cut for test run.
Video posting soon; seems to be more efficient than v1?
See the fleet
I think the sponsons were widened to accommodate more capacity/higher volts.
Vidja of it runnin please sir.
Yep, still propping up! That was octura 452.
Need to work on the bounce in the turns, but otherwise, pretty successful maiden!
See the fleet
Looks like shes a good runner Jesse. I see you're a Limitless owner also. I picked one up at the end of March. She's all most ready to go.
