In case you hadn't seen these yet...
Polycarbonate Hull: Two-piece shoe box construction for extreme hull durability. Molded composite material is much more impact resistant than fiberglass.
Polycarbonate Canopy: Durable 2.5mm polycarbonate provides a watertight seal and the thumb screws means no tape is necessary to retain hull on to hull.
Spektrum Marine 4685 4 Pole, Water Cooled Motor: Rated at over 5 horsepower with 85%+ efficiency, this powerful 8S capable brushless and waterproof motor provides more than enough torque to hit 55+ MPH.
Spektrum Smart 160A High Voltage, Water Cooled ESC: Able to handle all the power needed, it is programmable, water cooled, waterproof, and Smart.
Aluminum Propeller Strut and Rudder: Both the propeller and rudder feature anodized aluminum. The runner has a special break away feature that protects the hull from damage in case floating debris is struck.
S904 1/6 Scale WP Digital Servo: The high torque digital servo provides all the necessary power. Waterproofing makes sure the servo is up to the task of being in a boat without the risk of failure do to getting wet.
Boat Stand: This custom molded plastic stand fits perfectly to the contour of the hull providing a rock stable platform to display or work on your boat. This boat stand will last for the life of your boat without the need to worry about water rotting a wooden stand.
