Originally Posted by
Nick1979
I am about to purchase a used 36" Zelos. I am already planning on swapping the stock motors with larger Leopard 4074. Does anyone know if the 4074 will fit with the stock motor mounts in the Zelos/Miss Geico? Thanks
It will fit, but that motor is going to add a lot of stress to the mounts, so eventually they will pop the mount loose. Motor is quite a bit longer so has more leverage against the mount when the hull bounces, etc... I also found that the mounts would rotate around a bit, even with the screws really tight. Once you get them located, might need to do something to help "stick" them in place.
Darin E. Jordan - Renton, WA
