Results 1 to 3 of 3
Thread: Leopard 4074 1650kv prop size
    Dec 2015
    OR
    31
    Default Leopard 4074 1650kv prop size
    I'm going to build an outrigger around 33
    " running 6S with the Leopard 4074 1650kv motor and Seaking 180 esc.
    What would you guys recommend for props I'm thinking something in the 1.6 to 1.7 pitch ratio range, and 42 to 45 mm dia range.
    Does anyone run this motor and KV what props do you use and what do you like?
    Jun 2011
    789
    1816-1817 and 1817/3 ABC's work for me on a 34" rigger I have with a 1600kv 4074. You are correct with diameter 42-46mm depending on how much weight your carrying.
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    Dec 2015
    OR
    31
    Very nice boat! thank you.
