Mechanically the boat is now complete. I am awaiting a 63mm three-blade propellor. I had intended commencing with a 60mm 3-blade, but due the lower rpm of running 8s, I skipped the testing phase of running with the smaller prop. Still to do are the electrical connections. The Hifei 300 amp ESC will be mounted just forward of the motor so will connect directly to the motor. The Hifei battery connector/capacitor board still needs to be soldered to the ESC inputs. As there will be two 4s batteries in series each side then I need to solder the electrical connection to join the batteries to the capacitor connector board in parallel as the Hifei ESC has four input wires. I will fit an additional four capacitors each side which hopefully should be sufficient.
As regards one steering control cable being nearly 2 cm shorter than the other, I needed to mount the servo horns slightly off "centre" to allow the shorter cable to protrude a little further through the cable clamp on the port side servo horn. Aesthetically the artistic side of my brain did not like this as it makes the servos appear not centred, however, with the deck lid on this will not be seen. On the longer starboard side cable I was able to fit a secondary clamp so should disaster strike with the port side cable then I should still have steering control to the right to "get me home".
I can finally see light at the end of the tunnel on this build with another possible build in the future. I like to build as it keeps my brain stimulated and leave the testing to my son.
