Results 1 to 1 of 1
Thread: Strut upgrade?
    Sep 2015
    13
    Default Strut upgrade?
    Hello all, my wifes UL-19 is on its 2nd replacement strut due to highly worn bushings, I can't locate replacement bushings, and would rather prefer a strut that uses the tried and true octura bushings.
    Current setup
    GOOLRC 1500kv 4 pole 3680
    CC MMX8s set to 75% limit with stock timing
    8s1p GensAce 6k mah 100c packs
    X445 s/b prop
    Next change is replacing the CC controller with a spare schulze 32.115, and I might move her to a lehner 1950, but these older GOOLRC motors are quite amazing little motors for the cost.
