Results 1 to 3 of 3
Thread: new motors for twin zonda
    Aug 2015
    199
    Default new motors for twin zonda
    Well here's the deal,
    I think it's time to need to replace the motors in my twin carbon zonda 41". Last run of last year, one motor would kick in and run after about 10/20 feet after hitting throttle. Swapped motors and same thing with same motor. Same out of water, testing it.
    Stock is sss3674 2075kv's. Upgraded to sk180's seaking ESC's, dual water cooling, dashbota props (1718s I think, cannot read it, even with granny glasses)
    Normally run 4s 5000mah 50c, occasionally run 6s 5000mah 100c (what they say) Maybe run 10/15 times a summer.
    Would getting leopard motors be better? Might even be able to flip for the TP3640 (36mmx75) 1935kv when taxes come in.
    But anyways, Hope you'all had a great Easter dinner with family (if possable)
    John
    Oct 2020
    ZH
    50
    I aim to buy a set of leopard 4082 1600kv and use 42-45mm props on 6s. will go well with those 180?s I believe. Run slightly more than you. Lot of other stuff in spare time.
    Verzonden vanaf mijn iPhone met Tapatalk
    Mar 2020
    NH
    326
    If you go for a pair TP3650's you get serious fast
