Results 1 to 3 of 3
Thread: Motor size for a 60" cat to replace a 30cc gas engine?
    Dec 2015
    OR
    31
    Default Motor size for a 60" cat to replace a 30cc gas engine?
    I'm thinking about trying an electric motor in a 60" cat with a single screw.
    I would like to hopefully be able to run the same props that I do with the modified Gizmo 30cc + engine. The idea being a simple power train swap out.
    I would also like to run 12s as that is what I run in my heli's.
    Would something like the TP Power 5850 10D 720KV and a 200 A esc work?
    What sort of mAH would work for a good 6 to 10 minute run time?
    I haven't found much info on anyone using a single motor setup on a 60 inch cat.
    Any tips, links, or info greatly appreciated.
    Mar 2020
    NH
    319
    Hi Chris i should go for a TP5680 or a sss56114 (cheaper motor)or if money is not to important a Lehner 3060 or 3080
    Mar 2020
    NH
    319
    A 3080 is to much
