Results 1 to 2 of 2
Thread: Bullet connectors
    Oct 2020
    68
    Default Bullet connectors
    Is there anything I can do to make connecting and disconnecting the 6mm bullet plugs to esc smoother, one side I can hardly get the connectors to fit and it is really hard to take off.
    4,119
    Use a needle nose pliers and apply gentle pressure to the fingers on the male bullet, squeezing them inwards. repeat a few times and turn the bullet to compress from all sides. Don't bend them too much, or you'll reduce the contact area and cause an increase in resistance.
