Results 1 to 5 of 5
Thread: Linkage rod/thru transom grommet
    Oct 2020
    68
    Default Linkage rod/thru transom grommet
    On my boat I have the linkage rod on the top servo horn for maximum throw, the linkage rod has a bend in it when I run it through the thru transom grommet out to the rudder. Is the bend/flexing and rubbing ok? Servo seems to move fine.
    Jul 2016
    QL
    152
    Are you saying the linkage rod rubs on the transom grommet, causing the rod to bend as the servo moves through its arc of travel? I'd say probably not ideal. Are you able to take the linkage out and bend a kink into it so the rod can pass relatively cleanly through the grommet? Might take some trial and error to work out where to bend the rod and by how much. Maybe rig up some brass wire to make a template to work out the angle, then bend your linkage rod to match?
    Oct 2020
    68
    Quote Originally Posted by hughb View Post
    No the linkage rod is already bent/curved cause the the grommet sits low. Servo is high grommets lower rudder rod hole is higher.
    Feb 2019
    NY
    385
    I'm thinking pictures would really help here.
    Oct 2020
    68
    Quote Originally Posted by 1coopgt View Post
    https://imgur.com/gallery/c34W4kX
