Originally Posted by
dasboata
Howard is the rudder long enough ? 1-1/2" below the prop tip about ?? tilting the rudder back will help the stuffing in the turns,, but sounds like you might be giving the boat right causing the boat to lift the rear putting the bow in & causing it to hook ???
Tilting the rudder was going to be my answer too, but isn't it tilting the bottom of the rudder forwards if you need help keeping the nose up in turns?
Photohoward
Yes. But the prop sits pretty high so almost not even in the water.
That won't be helping, increased prop walk is the main detriment of a high strut.
