Anyone need a servo for a "big" boat? I have an extra HiTech HS-1000SGT giant scale servo that is new in box. This will output 1100-1500oz-in on 3S or 4S lipo input.
If anyone is building an open class tunnel or offshore boat this would fit the bill.
Asking $200 shippped CONUS. I can ship international at buyers expense.
This is listed on other sites.
Specs for HiTech website.
The ultra heavy duty, giant scale HS-1000SGT delivers digital precision and high voltage punch to your most demanding projects. Designed with an all-aluminum, EMI-shielded case, solid steel gears and non-programmable digital circuitry, this powerhouse servo can tackle the most extreme 1/5th scale vehicle stunts and giant scale aerobatic maneuvers in addition to the industrial applications that inspired its original design. Capable of operating on 14.8 volts, the HS-1000SGT is the ultimate in power and durability.
Features
Non-Programmable Digital Circuitry
EMI-shielded Cases
Durable Steel Gears
14.8v 4-Cell LiPo Capability
HS-1000SGT Servo Specifications
Performance Specifications
Operating Voltage Range (Volts DC) 11.1V ~ 14.8V
Speed (Second @ 60?) 0.26 ~ 0.19
Maximum Torque Range oz. / in. 1167 ~ 1528
Maximum Torque Range kg. / cm. 84 ~ 110
Current Draw at Idle 130 mAh
No Load Operating Current Draw 1300 mAh
Stall Current Draw 6500 mAh
Dead Band Width 2 ?s
Physical Specifications
Dimensions (Inches) 2.52 x 1.30 x 2.87
Dimensions (Metric) 64.0 x 33.0 x 73.0
Weight (Ounces) 12.80
Weight (Gram) 363.0
Circuit Type XXXXXX
Motor Type XXXXXX
Gear Material Steel
Bearing Type Dual Ball Bearing
Output Shaft (type / ?mm) Mega 15
Case Material XXXX
Dust / Water Resistance N / A
Connector Gauge (AWG) / Strand Count XX / XX
