Results 1 to 3 of 3
Thread: Antenna mount
    Oct 2020
    68
    Default Antenna mount
    Should I epoxy the aluminum mount to the boat once the hole is drilled? Or is tightening down the nut enough?
    Aug 2018
    Ky
    176
    I personally have just always tightened the nut. Never had any issues. Maybe put a little loctite on it.
    Apr 2020
    702
    Also, use at least one rubber O-ring, between the antenna mount & hull, to seal it against water getting in. Adding a second O-ring, between hull & nut, couldn't hurt.
