Results 1 to 10 of 10
Thread: Thru hull water pickups
    Sep 2020
    OR
    15
    Default Thru hull water pickups
    Anyone out there have any preferences on any of the water pickups that OSE offers? It's going into a flat bottom drag boat. Thanks!
    4,119
    location, internal obstructions, and a clean installation are more important than the exact model. They need to go far back on the hull where they'll always be in contact with water when the hull is aired out. Close to the keel on a V-bottom and as low on the sponsons as possible on a cat.
    Sep 2020
    OR
    15
    Thanks for getting back to me. I've used the Octura pickup in the past and it worked well enough, but if there is a better one available, I'll give it a try. Thanks again.
    2,731
    With a flat bottomed boat at speed you are unlikely to have any one part of the hull in the water consistently, I would look at a rudder blade pickup or a prop wash pickup instead.
    If you really must have a through hull pickup, I would recommend making your own, a simple alloy or brass tube intake is much more efficient than any of the commercial offerings I have seen, so you will get bigger gulps of water whenever it touches the water.
    Sep 2020
    OR
    15
    Ok, that is good advice. Thanks.
    Jun 2020
    OH
    I raced a flat bottom boat for 20 years, the water pickup was on the cavitation plate just to the right of the rudder. Never had any overheat problems.
    Sep 2020
    OR
    15
    That's a good idea, I like it. Thanks.
    Jul 2022
    Fl
    11
    Hmm. Interesting. I like the idea of the OSE thru-the-hull pickups. I'm considering a pair for my Blackjack 24. I thought that a good spot would be the aft end of each sponson. Is that not going to work? Seems they would always be in the water.
    May 2018
    344
    Spotted this design at Performance.
    Jul 2022
    Fl
    11
    Default Missing images?
    Quote Originally Posted by Mike W View Post
    I can?t seem to open the images
