Results 1 to 3 of 3
Thread: Futaba 3pv
    Oct 2020
    68
    Default Futaba 3pv
    kind of confused on how to set this thing up, don’t know what settings to adjust.
    For the throttle setting do I need to reverse channel 2?
    Do I set throttle trim to 100?
    3,117
    I assume your trying to arm an ESC. Yes, the Futaba radios require the throttle channel to be reversed. I try to leave all of the trims and EPA's settings neutral then adjust as necessary to get it to properly arm. Each ESC has their own adjustment requirements.
    What ESC are you trying to arm?
    Oct 2020
    68
    seaking 180a esc
